View the IPv4 address bindings that IPSG allows.
- Select Source Guard.
- Select the IP Source Guard-addresses tab.
IP Source Guard-addresses Field Descriptions
Use the data in the following table to use the IP Source Guard-addresses tab.
Field |
Description |
Port |
Indicates the port on which IPSG is configured. |
Type |
Indicates the address type. |
Address |
Indicates the IPv4 address that is allowed by IPSG on the port. |
Source |
Indicates the source of the IPv4 address, which is DHCP Snooping. |
